AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Tue May 27, 2003 5:28 pm
Welcome to NICO!!!
Ditto what Brian said. A friend and fellow NICO member here in Phoenix is in the middle of designing a true cold air intake for the 97-01 Q's. Skip the Denso plugs, as you will be inviting trouble - Replace with factory-spec NGK's and you'll see an improvement in power. I'm on the fence as far as the exhaust. Looking at the 97 system, I'm inclined to think it could use some freeing up... Of course, this will cost you some quietness, but I'd go with a stainless Ultraflow... Same setup as the more expensive Stillen unit. POP charger is a true waste - Sucking in hot underhood air negates the TINY increase in flow.
Anyway, let's see some pics of the Q, and enjoy our little site!
