genkdis wrote:(ask no more than $3-400 in parts besides oil changes every year), I will be a very pleased camper.
Short answer: It aint gonna happen... I dont think youll ever come across a Q that will need less than 300 in parts a year... I suppose it *could* be done, but wanting to put 100k on it and KEEP it running would be real tough.....
I think a better idea on what to spend for parts is more like 1000ish.. The 97-01 Q45 (FGY33 generation) are very reliable, and tend to have less breakdowns as the earlier Qs, and also less finicky problems. The G50 (9096 Q) is a fairly fussy car, and if your anal about everything, youll always have something to do.
The Y33s seem to be more solid, and generally regarded as bulletproof. Youll want to find one iwth real good maintenance history (key), especially if you want it to see well into the 200k range.. Most things (on any car) really start to break after 100k....
It all depends on how picky you are.....
Doing a quick reality check, if you do your required maintenence fluids, (ALL of em, transmission, brake, oil, PS, rear diff) brakes, filters, spark plugs and other tuneup items, as far as REPAIRS are concerned, 300/yr might not be a bad thing
2400 over 6 years (worst case) in jsut replacement parts (of things that need replacement because they have failed), not including maintenance related things, may not be too bad... Ive spent 2000 in one year on my Q... At this point, i havent spent any money on replacing things that have "failed" and will cause the car to not run..... My Q has never failed to get me from point A to point B
Bottom line, you will be doing a lot more things, and if you dont mind handling a little more car, then you will have ot pay more... If you dont mind that (and its *really* not *that* much more) then the rewards make it worth it. if you like driving a quality automobile and are wiling to pay for it, go for it.
Otherwise, if a car is simply a mode of transportation, look away from any Q45..
