tq1 »
https://forums.nicoclub.com/tq1-u184316.html
Sat May 14, 2011 2:47 am
The lights that stay on are; TCC OFF, ABS, SLIP. Tthree individual lights, or indicators. After consulting the trouble codes and taking the vehicle in for diagnostics I was told it was the throttle position sensor. Did the resistance check on TPS and while sensor was still installed I check the resistance and no difference in OHM readings was detected so I went ahead and replace TPS. I did the resistance check on the old sensor and it worked fine, once taken off of the car. So I spent 75 dollars for nothing with that issue. Lights still illuminated. Took vehicle to another repair shop and he also used the diagnostic machine and reset my check engine light and turned it off. He put the more advanced diagnosed machine on the vehicle and now he tells me it is a Left rear sensor short in the wiring circuit. I do not know where this particular sensor is located and would like to know if you may be able to assist me in locating it and maybe showing me a pictorial of the sensor and itt's wiring locations so I may try and resolve this. The strange thing is that when I first unplugged the Throttle position sensor harness the light went out for about 1 mile then turned back on. The resistance check which I was adviced to do did not tell me to take off sensor first, so I though maybe the mechanical connection to the TPS sensor which I though should move when the throttle cable is pulled on giving me a varying resistance value, due to it being a type of variable resistance type of device.
