I searched the forums and saw similar problems but not my exact problem. Tonight when I started my car the instrument panel/gauge lights did not work as well as any lights related to dimming (ac, etc). Also when the doors are opened the automatic dome light didn't work. I know it isn't a bulb issue as they all went out at the same time and like other posts, I didn't see any fuse related to dimming instruments. I tried banging on the dimming switch as some have mentioned and made sure dimming was all the way up with no luck. Also, the dome light does work when on ON. Please help if you can or have had similar experience!
Thanks so much!
