1997 Q45 Cranks but no start
suez308
Car: Infiniti
Moved car last night and shut it off. Tried it this morning and it cranks but will not start. This has happened before; think it has something to do with not keeping the car running which I was told is an issue with this car. Last time it happened we had to tow the car and the Infiniti dealer reset the AAC valve which was out of range. They also changed the oil and filter because the car was flooded. I found the AAC valve but do not know what to do with it to "reset" it. Any help will be appreciated.
qship96
Car: 1996 Infiniti Q45
try starting it with your foot to the floor on the accelerator
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
You must leave it run for at least a couple of minutes (when it has some heat ) Flooding is very hard on the engine, and the starter.holding the pedal to the floor keeps more gas from being pumped into it while cranking, thereby clearing the flood faster.
