1997 Q45 compatible replacement front coil springs?
chrisbr66
Car: 1997 Infiniti Q45t
Question for the group. I am replacing the front struts on my 1997 Q45. I got the struts from Amayama without the springs, unfortunately the mechanic snapped the old springs when removing them from the car. I tried Amayama again but they are saying they can't get them. Does any one know anywhere to get these springs, or is there another spring that would be compatible? Thanks in advance for any help.
98_Q45
I’m wondering the same thing…though suspect one of the G or QX models might have a similar length that just isn’t being shown as a substitute. If even the Maxima or i30 ones could fit
fontana dan
I imported suspension components through Jesse Streeter in 2022.
Found just now on Yahoo acutions is a set of 4 used springs for Y33. I think there is a difference either in front springs or front shocks between V6 and V8 Y33 models though, might want to do your homework on that.
If you import this set I will buy the rear springs off of you.
https://auctions.yahoo.co.jp/jp/auction/l1168526042
https://jessestreeter.com/
chrisbr66
fontana dan wrote:
Wed Jan 21, 2026 8:39 pm
Thank you for the info, I'll contact Jesse and see if he can find out any other info on the auction
Chris
chrisbr66
chrisbr66 wrote:
Thu Jan 22, 2026 8:57 am
Chris
Thanks for all the help, I was able to use Jesse Streeters service and won the auction. The springs were correct and now have a good set of struts and springs. For anyone else I did find out you can still get the springs thru Amayama, part number Nissan 54010-6P105 - SPRING, FRONT, not cheap 205 per spring plus shipping but it is an option
fontana dan
chrisbr66 wrote:
Fri Feb 13, 2026 9:13 am
Great to hear Chris, glad I could help. Did you get the used set of springs?
I might have to contact Streeter for some rear springs since mine are sagging a bit and throwing off the camber. Not sure where else to get them at this point.
chrisbr66
fontana dan wrote:
Sun Feb 15, 2026 9:36 am
I did get the used set of springs, won the auction for only 50 bucks (shipping was over a hundred) I had the mechanic change the rear springs also since they were included in the set.
