1997 Q45 Brake Help
osudelt69
Hey guys, this is my first post here. Looks like a nice site.Helped my cousin do brakes on his 97 Q45. Having a problem on driver side front.
Car has a knock when driving. The driver side brakes did not have the anti-rattle clips. They were gone. Also we did not use shims. Under braking load, the car stops perfect and there is zero noise.
Having a very difficult time finding new anti-rattle clips. Dealer wants $60. Was going to replace the brake pad caliper clips and see if that helped. Any suggestions would be great.
Thanks,
Marc
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Shim kit from Joe is always a good thing to have on hand
http://www.infinitipartsusa.com
Modified by maxnix at 10:31 PM 6/9/2009
qship96
Car: 1996 Infiniti Q45
Anti rattle clips{pad retaining clips} are available for the Q at most chain stores{autozone,etc} however the shim kits are not. Not sure why....
osudelt69
qship96 wrote:Anti rattle clips{pad retaining clips} are available for the Q at most chain stores{autozone,etc} however the shim kits are not. Not sure why....
Do you have a part number? I've tried autozone, advance auto parts, and KOI. No luck at any of those places. What do you suggest?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Read my post. Don't accept cheap Chinese substitutes.
osudelt69
maxnix wrote:Read my post. Don't accept cheap Chinese substitutes.
I only se them listed for the rear brakes...I need them for the front. If I overlooked them, sorry. Just don't see them
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
There are probably at least 250K parts. Not all make it online.
Call them with your VIN.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
It sounds like you have two problems:1. Missing brake shims and anti-rattle clips2. A suspension noise ("knock") which could be a number of things but a guess would be strut mounts, tension rod, swaybar endlink.
good luck, junkyard would be a great source for the clips.
osudelt69
I found some for 7 bucks at a local auto parts store. Carlson Brake Parts makes the kit. Part number P691 if you guys are interested. Comes with pad clips and anti rattle cliips.
No noise on the brakes, but have a new problem. The lug nuts are slowing backing off after driving a few miles. I'm a little lost here...are the threads stripped?
Car has 175xxx miles, it is a 97. We used an air impact and then checked to make sure they were tight with lug wrench...
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Impact wrench, if not set properly, can strip your lug nut/bolt and even warp the rotor. Torque spec for the lug nut is 72-87 ft-lbs.
Rod
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
loystock wrote:Impact wrench, if not set properly, can strip your lug nut/bolt and even warp the rotor.
Perhaps more immediately troublesome, it makes the lugs difficult to remove without an impact wrench, too. I get tired of asking grease monkeys at tire shops not to use impact wrenches on my cars. Last thing I need is to get stranded on the side of the highway with a flat tire I can't change because some kid couldn't be bothered to hand-torque my lugs.
osudelt69
thanks for all the help, will try new lug nuts with my torque wrench? hopefully its not the lug bolts! are the bolts sold individually or as just the hub ?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
osudelt69 wrote:are the bolts sold individually or as just the hub ?
Joe is your friend
http://www.infinitpartsusa.com
