I went to start my truck and it wouldn't start. I had had a problem once before with the shifter moving with the touch of a finger a year ago which fixed itself and never happened again, so seeing how I had just driven to the store I thought the reason my truck wouldn't start was because the shifter hadn't gone into park. I tried moving it through the gears, tried starting it in neutral and still wouldn't start. It's an automatic. I called AAA to have it towed. When the guy got there I told him it wouldn't start..it wasn't the battery, and he got under my truck and starting moving the shifter back and forth from underneath the truck. Nothing he did got it to start. Before he did that it was clicking into each gear. After he messed with it, it started to slide through the gears without engaging and then jammed into park position and wouldn't move at all. He again messed with it and it was going through the gears again but still wouldn't start.
I had it towed to our mechanic, who tapped the starter with a hammer and the truck started (so it wasn't the gears in the first place it was the starter) but whatever the AAA guy did has messed everything up. The car can be put in neutral and pushed and it will move. But when you put it in drive or reverse the truck feels like it wants to move forward, so even putting it in reverse it's like it's in drive. It's as if you have your foot on the brake and it will not move. My mechanic ran diagnostics on it and no codes show up at all. He has checked all the linkage on the transmission under the car and there are no broken cables, he said everything looks the way it should. My brake lights are working properly, they are not stuck on nor do I have a blown fuse for the brake lights. Emergency brake is not on.
The truck starts fine, you can hear and feel it go into gear when you move the shifter . As I said even when it's put in reverse it lunges forward instead of backwards and won't move. It has been at the mechanics for 3 weeks now and they still cannot figure out why it won't move or why it seems to be stuck in drive no matter what gear it's in.
