ptwohey »
https://forums.nicoclub.com/ptwohey-u104111.html
Wed Aug 20, 2008 1:23 pm
There is "something" within the rear brake line system to this '97 that needs fixin'. A bracket with a spring has broken away. It bolts to a small nut plate on the differential housing center and is connected by a 1" diameter spring to the brake "something". There is a lever on that "something" that moves in and out as the differential moves. I see several brake lines going to and from this unit but have no idea what it is or how it works.
I know this description is odd but maybe someone knows what I'm looking at and what it does? My Pathfinder runs, goes forward and stops without problems but this "something" must be there for a reason?
