1997 pathfinder evap valve
RY2K
Car: 1993 GS300
1998 GTi VR6
this is leaking
its by the gas tank in the rear
can any one tell me what its called
Thanks
Ryan
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
EVAP canister vent control valve? :gotme
What's the OBDII code?
RY2K
Car: 1993 GS300
1998 GTi VR6
ok
P0443
Towncivilian
Yeah, that thing is the EVAP Canister Purge Control Valve. See page EC-230 of the FSM.
I tried to find a part number on Courtesy Parts, but had no luck.
ARKQX33V6
You need to remove carefully clean lubricate and remove the rust and verify the pipes rubber hoses are fastened securely. Then at least undercoat that area but if that area is rusted as bad as it shows in the picture , what is the rest of the car at.
These vehicles are rust prone but continued under coating not only slows rusting but:
keeps rubber supple
keeps corrosion down on electrics
lubricates between body panels
Drive rust out and this can been seen after a rust proof application
helps control rusting of larger components.
Your 97 compared to my 97 will show what I am expressing
