When it was first getting stuck occasionally yes I did use some wd40 and it helped for a while. Then today it didn’t come up at all after several tries. Then worked again like nothing happened.VStar650CL wrote: ↑Fri Apr 29, 2022 9:21 amHave you tried lubing the mast? Very often a little WD40 or high-vis silicone will straighten them right out.
Thanks for the pics Md!mdmellott wrote: ↑Fri Apr 29, 2022 11:02 pmIf you want both antennas to be available to your receiver, place a small jumper wire into the two receptacle plug holes on this adapter and then plug the Nissan antennas in as usual. I used the Metra 40-NI11 adapter which has just the one Motorola type plug. This jumper will work the same with the Metra 40-NI10 adapter as well. The second wire with the socket connection isn't used on aftermarket receivers. I replaced my ugly 32" mast antenna with a stubby 5" billet aluminum antenna but got lousy reception until I jump wired the adapter receptacle. My receiver reception is clean and clear with the windshield antenna now picking up the radio signal. The stubby was just for looks. You really cannot beat the reception quality of a long mast antenna but I think they look tacky. IMHO
I didn't realize there was more going on than just a difunctional antenna motor. Be sure you unplug power to that antenna just in case it has a shorted circuit. There is some type of electrical gremlin fouling you up. It's been a year now since you replaced your previous Pioneer with this new Pioneer system, due to gremlins wreaking havoc with your reception and antenna. post6823270.html#p6823083 Your old PAC integration device you had working with the Kenwood system, prior to that old and new Pioneer system installs, that I assume you are still using now, may having wiring or programming issues. I don't know much about audio tech stuff. I'm thinking you have something external from the head unit that's been firing split balls at your audio systems. I'm not much help here for this one.
I'm glad this worked out for you. All I can think of regarding the jumper hack not working is either the faulty antenna motor was still plugged in and giving you issues or, if it was unplugged, a break in the stenciled on window antenna had killed the reception. Like the rear window defroster, a hairline scratch across the painted on line will kill the whole line. The antenna wire connection at the lower left of the windshield, behind the pillar molding might also be the problem. Recently installed Kickers come to mind. Just a thought.
