1997 Pathfinder 4x4 Rear Differential swap
A1218
Car: 1997 Nissan Pathfinder SE
Hey everyone, the rear diff in my Pathfinder with 235k miles hums pretty loud on the highway between 50 and 70mph and is now making noises at lower speeds. I also hear a growling noise around 20-30mph when slowing down. Recently, when putting the vehicle into drive or reverse, I hear a clunking noise. I had someone shift gears while I was underneath the vehicle and I visbily see the driveshaft rotate at the diff. Nothing is shifting at the tramission mount and no noise is coming from there.
I was thinking of purchasing a 3rd memeber and swapping it out without removing the entire assembly. The plate under my hood says HG46 for the differential and I found one on ebay that appears to be in excellent condition and is also an HG46. However, this one is from an 01-02 frontier 2WD (there is also a plug connector on it, which mine does not have). Will this swap into my vehicle?
I read online that the HG46 axles had 31 splines pre 2000 and 33 splines post 2000?
mdmellott
Car: '13 Kia Soul+ 2.0L AT
A1218 wrote:
Sat Oct 04, 2025 4:43 pm
Nope. 33 axle splines and a different gear ratio. all-you-needed-to-know-about-nissan-axl ... 33955.html
A1218
mdmellott wrote:
Sun Oct 05, 2025 7:40 am
So mine is 33 splines but a different gear ratio?
Do you think it is a good idea to rebuild my current differential?
mdmellott
This is what is written on that March 2007 NICOCLUB post.
HG46 - found on auto equipped pathfinders, 96-97 hardody 4 bangers, many Xterras and Frontiers. This one has some variation. Pre-2000 versions are the H233B axle with 4.625:1 gearing (31 spline axles). 2000+ is the H233B axle with 4.636:1 gearing (33 spline axles).
Yours is a 31 spline with a 4.625:1 gear ratio. The one you are looking at on Ebay is a 33 spline with a 4.636:1 gear ratio.
I don't think it's is not a good idea to rebuild your differential with that Ebay part that doesn't match your vehicle.
mdmellott
mdmellott wrote:
Sun Oct 05, 2025 4:46 pm
I don't think it's is not a good idea ...
Sorry about the typo. I don't think it's a good idea.
