Big-Bird »
https://forums.nicoclub.com/big-bird-u44704.html
Thu May 03, 2007 2:44 pm
Sounds like moisture either in the fuel system or in the distributor cap ( it could also be a weak spark plug wire).
Purchase some gas-line antifreeze ( methyl-hydrate ) you need about 4 oz. Pour 4 oz the fuel tank. The methyl-hyrate will bind with any moisture in the fuel and help it burn in the engine.
Second: Remove the distributor cap and check the condition of the cap's base seal. A cracked seal will allow moisture into the cap and cause the sparks to go everywhere at random. (water is the perfect conductor for high voltage electricity) Especially a coil that snaps off 30,000 volts or more with each firing of a cylinder.
If you do have a bad spark plug wire, or even a bad cap the moisture will cause the spark to ground on the outside of the engine instead of at the spark plug.
This is real easy to check, but you need a dark place to do it so you can see any sparks jumping.
Get a spray bottle filled with water.Run the engine.Spray the spark plugs, wires and distributor cap with a mist.Listen for the arcing ( a snapping sound) and look for a spark being where it shouldn't be.
Look for sparks at the wires boot ends, possible cracks in the distributor cap, old dry cap seal, cracked ceramic on a spark plug.
IF these items don't help you find your problem get back to us here.
