Divitom »
https://forums.nicoclub.com/divitom-u40768.html
Wed May 17, 2006 12:36 am
While this may seem like a lot of work, pull one of the rear speakers and look at the wiring. Typically there is a stipe or ribs on one of the wires indicating which is positvie or negative. They key is that you wire them all the same. It doesn't matter which you hook up to where as long as all the speakers are the same. If you don't you'll end up cancelling out the bass and the seperation will so distinct that the vocals won't appear out of the center but as if they're coming out of each speaker - Also, the spade lug size is usually different.
