A1218 »
https://forums.nicoclub.com/a1218-u297613.html
Sun Mar 31, 2024 7:51 am
I'm having some issues with the a/c on my Pathfinder. I'm not too sure if it's the a/c system or the HVAC control unit in the vehicle, but to get cold air blowing the dial has to be turned down to 65, the lowest it can go. As soon as I turn it a notch or two higher, still well into the blue range, warm air starts blowing out. It not too warm in the NYC area, so there is defintely some issue going on here. Could it be the mode actuator assembly, the HVAC unit, or simply needs a recharge? I don't see any visible leaking or resude around the connections under the hood.
