Hi,
I have a 1997 Nissan Maxima SE and the antenna won't go down. I hear a grinding noise from the motor. When I push the antenna down manually and then turn on my radio, then antenna won't go up all the way and I again hear the grinding noise. I don't know if the entire motor assembly is bad or just the gears? Anyway, I attempted to fix it myself but access to the antenna motor is blocked by a metal sheet that's part of the trunk. The metal sheet is near the OEM jack. It's a tight fit and I don't think I could replace the motor without somehow moving this metal sheet. Is this metal sheet movable and how can I repair the antenna problem myself?
Thanks for any responses and I apologize if this is a repeat post.
vn_bn
