loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Nov 10, 2010 11:56 pm
The Battery and Brake light coming on is indicative of problem with the charging system or a partial short somewhere, draining too much current and lowering the alternator output. You may have a new alternator but the output is marginal (I've seen this in refurbished ones).
First, make sure the battery connections are clean and tight - no corrosion. A fully charged battery should read 12.6 or higher with engine off. With the engine running, the alternator charging voltage must be STEADY (no fluctuation) and must be > 13.8 VDC (spec is 14.1-14.7 VDC). Check all the fuses in the engine compartment. Check the wiring, especially on the alternator side as it is possible to have 'crossed wires.' Check the battery cable for corrosion, especially the 'hot' (+) side which can be shorting to ground. Check the wiring under the fusible links/fuses.
Have you done any modification to your headlight (high wattage bulbs)? Are the headlights working good? Check the condition of the wiring to headlights.
