Electrok-d »
https://forums.nicoclub.com/electrok-d-u256795.html
Mon Sep 28, 2015 7:56 pm
I've got a really strange situation. Across a year of fixing issues associated with various trouble codes, I finally have one left: P0141. It is associated with the down stream oxygen sensor's heating element not reaching 600 degrees fast enough.
Since the original had over 100,000 miles on it, I figured just swapping it out with a new one would fix it. Nope. First I tried a Bosch universal, then a Bosch Platinum original fit, then a Denso, and then finally another Denso.
All the while, I checked everything along the list in the factory manual. The circuit actually works. The element gets hot. The sensor produces voltage and sends it to the ecu.
The factory manual states that the measured resistance of the downstream oxygen sensor's heating element should be 11.4 to 17.4 ohms at 77 F. Every sensor that I measured, even the original one I took out of the pipe, measured between 4 and 5 ohms. I even took the last Denso to the bench, applied heat, and took a measurement. I couldn't get it over 8 ohms resistance. That is three different manufacturers all measuring something different than what was stated in the manual.
I'm using a Denso 234-4703. This cross references to the OEM part number, which is 226A0-1S715.
Has any encountered anything like this before?
