The check engine light illuminated again after last repair (read out stated that there may be a problem with the speed sensor, which was just replaced as well as a possible electrical problem stemming from somewhere around the mass air intake). The symptoms are as follows: not all the time but often the car dies during idle, stops, etc. When restarted, often but not all the time, black smoke and choking sounds, hard to get moving.
I've replaced knock, oxygen, speed sensors; tuned up; replaced fuel filter; nothing helps. I am a Katrina survivor and $$$ is tight. Can I clean the mass air intake? If so, can you tell me how.
Any assistance MUCH appreciated.
