vonscorpio »
https://forums.nicoclub.com/vonscorpio-u242950.html
Fri Feb 12, 2016 1:47 pm
Assuming the history to be poorly maintained, as it was with my 97 I30, if you are comfortable doing the work yourself, I would recommend manually changing the oil and checking for any debris. You're looking for anything relating to the timing chain guides falling apart-- I've never had an issue, but it's worth checking.
I would change the coolant and change and flush the brake fluid.
At that mileage it is likely it either has a new alternator, or will need one soon, so I would take it to Autozone and have them check the charging system.
I assume the transmission might need something, but I am unfamiliar with the 5 speed and what it needs. Shocks and struts might be in order, and I know from my car (with almost the exact miles as yours) that the bushings on the front end are failing, along with the CV boots. I'm told if you put new boots on before its run too long with the boot falling off, you can continue to use the OEM CV axle. Someone else from the forum could probably weight in on this, but I am told the aftermarket axles and CV joints don't hold up very well.
Other than that, its been a very solid, robust car. 10/10 would buy again.
