loystock »
https://forums.nicoclub.com/loystock-u10145.html
Fri Nov 13, 2009 9:03 am
Welcom to NICO - the best car forum in the world.
FAS - Fuel, Air and Spark must come into the combustion chamber at the right timing for smooth combustion. Your problem may be as simple as water in your fuel tank, low fuel pressure (fuel pump, filter, etc) and/or ignition system (coils, pugs, timing, etc.) issues.
From the info provided looks like you have a dirty fuel filter (starting problem) and water in the fuel tank (backfiring). Water in the fuel tank us due to condensation which forms when the tank is kept below half full most of the time.
We'll start with the simple one - remove water in the fuel tank and replace the fuel filter. Before replacing the fuel filter, ensure the fuel line is empty - FIRE HAZARD, by pulling the Fuel Pump fuse (15A, fuse panel below dash board, driver side) until the engine dies. Crank the engine at least once to ensure line is empty. Remove and replace the fuel filter (on firewall besides brake booster).
Once fuel filter has been replaced, buy a full tank of Tier 1 gas (Shell, Chevron, etc) and at this time, Premium is preferred though regular gas is Ok. Add a bottle of Iso Heet Antifreeze and Water Remover into the fuel tank. Check the air filter - it may be dirty and needs replacement.
When you have time, clean the MAF (Mass Air Flow) sensor and connector. and throttle body. Use zero-residue Contact Cleaner on the MAF sensor and connector. When cleaning throttle body, be gentle with the throttle valve and never spray cleaner directly into the throttle body (can damage TV actuator/sensor). There are other things that you need to do to keep you car running smoothly by doing a SEARCH as well as reading the FAQ sticky in this forum.
OEM parts fuel filter can be bought from NICO sponsor, IoS - everythinginfiniti.com, @ 25% off MSRP. Aftermarket fuel filter can be obtained from AutoZone and the likes as well as Iso Heet, MAF Cleaner, Degreaser, etc.
Rod
