lovebites »
https://forums.nicoclub.com/lovebites-u23030.html
Wed Dec 08, 2004 12:03 am
Hi,
My j30 is usually sluggish when accelerating from a stop no matter how hard I step on the gas. About a 2-3 seconds later, however, it starts to spring out. I wonder if this is normal for most j30. In addition, when the gear is engaged into D, there's a shift shock about 1 second later not immediately.
Do I have to check the transmission or some others such as a throttle position sensor, revolution sensor, etc?
Additionally, my j30 has a hard time with start. When ignited, the car begins idling but shut off immediately. It happens especially when cold start. What's wrong?
My j30 is 1997 with 134,000 miles. I replaced timing belt and thermostat four months ago. I also changed transmission fluid at the same time. Thanks in advance.
lovebites
