1997 j30 »
https://forums.nicoclub.com/1997-j30-u80400.html
Tue Nov 06, 2007 6:19 am
Thanks for the support fellas……
Here is what happened…..I had the roof ½ way opened and when I went to close it the roof started to grind…?It eventually closed and I should have left it alone……But I did not…..I opened it and then realized it would not close….It will open by using the switch but will not close and elevate at the end of the cycle of closing….I do not mind if it is not functional, but would really like the roof to be able to seal and then I can unhook the switch….Once again thanks for the help….
