1997 Infiniti
sher123
Car: 1997 Infiniti I30
Good evening! I am curious if anyone can tell me where coil 3 is? I got a diagnostic code that said misfire on coil 3 and am trying to figure out where and what this is. I just bought the car for my son and it was not doing this before we changed the plugs and we also added some seafoam when we filled the tank up. :)
King Ranzo
Car: 15 Ford Focus ST
OMG CHER. I LOVE YOUR WORK.
Also, the coil is the ignition coil. That should be above cylinder 3. Did you properly plug the ignition coil back into the spark plug? That's usually the problem.
sher123
The problem is I don't know which one is #3!!! LOL I don't have nads I'm a girl!!!!
King Ranzo
is it a V6 or a 4 cylinder?
sher123
v6
sher123
It just says I30 on the back i have no idea of anything else. It has no manuals with it and I cant seem to find any engine diagrams online' I guess I'm just not looking in the right place!
That overhead diagram shows the firing order of your engine. Each cylinder is numbered.
Also, if its running fine just clear the codes and carry on.
King Ranzo
You can download the Factory Service Manual here:
http://www.nicoclub.com/FSM/i30/1996_I30/
It should tell you the order of the cylinders. It should be the third one in the front. That's how it usually is, but you might want to check the FSM to be totally sure. It's a pretty easy problem to diagnose so you should be fine :D
sher123
It just says I30 on the back i have no idea of anything else. It has no manuals with it and I cant seem to find any engine diagrams online' I guess I'm just not looking in the right place! Thanks for the links I will check them out! It was running fine before the plugs were changed and I put the sea foam in the gas.
Dattebayo
Can you see the picture in this post or not?
frapjap
'07 Subaru Legacy
if not, your cylinders are numbered as such from front to back:
5 6
3 4
1 2
Dattebayo
:facepalm: to me.
That's unicorn power for you right there.
sher123
Thanks everyone for the info. I hope we can get it fixed today!!!
THawks
Car: 2010 Rogue SL FWD Premium Iridium Graphite
dunno if troll or not...
SBC 240Z
potential boobs = tons of help?
SBC 240Z wrote:potential boobs = tons of help?
That explains why people are so helpful to me.
SBC 240Z
I said potential, not guaranteed
:gotme
