1997 Infiniti QX4 SES
cgillard
Car: 1997 Infinti QX4
Hi, I have a 1997 Infiniti QX4. Runs great but the SES light just came on. Can anyone tell me how to check what this is referring to? How can I get a code from the vehicle? How can I reset it if there isn't anything wrong. thanks in advance. All help welcome.
Project240
Go to Autozone, they'll check it for free. And reset it for you as well.
fueler
Car: 2 Nissan's
2 BMW's
Yes autozone has free OBD2 scanners for rent, and they can do it for you if you like. Really all you do is plug it in under the steering wheel, and turn the key to ON (without starting the engine) and it will tell the code and then you have the choice to clear it out.
cgillard
Thanks for the prompt response but I do not live near an Autozone. Is there anyway to read this code myself? I live in a small town. Thanks again.
fueler
Car: 2 Nissan's
2 BMW's
Just looked at a map, and WOW you must have a lot of off-road terrain available at your disposal!! Lucky!
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
You need to pull the ECU out from under the dash and set it to diagnostics mode by turning the screw clockwise waiting a couple of seconds then turning it back counter clockwise. This will cause the check engine light to start blinking. Those blinks are the codes that are stored. Come back with how many short blinks/long blinks and ill tell you what your code is.
screwinitupagain
Car: 1997 Nissan Pathfinder SE
Dude I just went through the same thing for like the past 2 months to try & get my car inspected (it won't pass if the SES light is on). http://www.4x4parts.com/ubbthr...50086
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
fueler wrote:Just looked at a map, and WOW you must have a lot of off-road terrain available at your disposal!! Lucky!
WERD. . not to mention, Yellowknife is the start of the Ice Road.
Can you drive on that in the winter or is it only for the truckers? I'd wanna slide around on it.
cgillard
Thanks for the response. There are some ice roads that are open to public use. They are pretty cool.
nissandoms47
That would be fun, then i could experience r50 drifting haha
