1997 Infiniti QX4 Overheating
jcnunez
On hot days if I turn on the AC my SUV begins to overheat. Once I turn off the AC it returns to normal temp. This only occurs when the temp is 90 to 100 degrees and the car is idle.
I replaced radiator fluid, water pump, thermostat, fan clutch/blade and hoses. I noticed no leaks in the radiator. Could there be a clogged chamber in the radiator? What else is there to check or replace?
Q45tech
Check speed of auxillary electric condenser fans that come on with AC.Check rad for bent fins and corrosion.............10 years is usually the life of oem rad, also any rubber foam air seals around rad.
Dirt. leaves, hair, animal parts between condenser and rad
The usual fix is rad replacement and other air flow items to make it like new.
