asnorton44 - appreciate the info.., but these are the same u-joints that Advance auto parts sells and they have issues with the joint holes as well. (they don't fit snuggly.., they fit loose..)
Anywayz.., I finally was able to get back under the truck tonight....
I found all my issues and solved them.
I replaced all u-joints with the precision series u-joints...(they fit barely snug.., but they work)..,
*** this was only one of the issues.., it didn't solve vibration ***
Sooo I tried testing the bushings on differential..., they seem some-what tight. A friend got under there with me.., we started checking all of the connections and then he grabbed the front driveshaft... I heard a "Clunk" sound when he did. We then traced the noise back to the output shaft of the transfer case....
The entire output shaft will move in a 1/4 inch direction whereever you want it to go...
I know personally that this thing is supposed to be solid. After more searching on this.., I decided to test this deal by jacking up rear of truck..(front was already up) and engaging the 4-wheel drive...
the ouput shaft will also move in and out 1/4 to 1 whole inch..... (up, down, side to side)
this effect was causing the entire front differential to move in all directions....
I just removed the front shaft and Whallah!!! the vibration was gone. On occasion I still feel a clunk through the floorboard.., but I now know what is causing the clunk vibration.
Sooo to sum it up..., I got to either fix the transfer case..., or replace it....
I surely dont want to do either on this. As it stands as of now.., I've had it with this truck
and am seriously want to sell it or trade it in on something just as dependable as it was.
I saw a 2003 s10 xtreme with 4 banger that is in perfect shape at a dealership and am seriously thing of trading for it.
I'm severely tired of this monster eating up my paycheck. The last 4-5 weeks.., it has cost me over $400.00 plus just trying to solve this issue.
Again.., To everyone here.., I appreciate all the info and links and stuff. But this truck.., if I have my way..., will be history in the next few months.
Thanks again..,
Daemeon2
