Postby
tommyg »
https://forums.nicoclub.com/tommyg-u18643.htmlMon Aug 09, 2004 9:30 am
My Infiniti Q45 was losing power (could not accelerate at times) and the check engine light was on, so I brought it into my local mechanic who diagnosed the problem as a bad mass air flow meter (no output). The part is extremely expensive ($488). Since I didn't do the computer diangosis myself, I want to make sure that they are replacing the correct part. Could the problem actually be something else (such as a dirty PCV valve), or is it pretty clear that this type of problem arises from a faulty air flow meter? Thanks!
Postby
redmanfx »
https://forums.nicoclub.com/redmanfx-u15036.htmlMon Aug 09, 2004 9:30 am
tommyg wrote:My Infiniti Q45 was losing power (could not accelerate at times) and the check engine light was on, so I brought it into my local mechanic who diagnosed the problem as a bad mass air flow meter (no output). Thanks!
Are you refering to the Mass air Flow Sensor or MAF as we call it? This is right after the Air in-take box and is a square shaped box that looks like it's sitting on the air intake hose? If so, you can find them cheaper and there is one right now on e-bay for $150 bucks almost brand new. Check E-Bay "Infiniti parts" it's on page 18 or so. If it is the MAF you're talking about I'll help you find one cheaper because $488 is alot of duckies...
Postby
tommyg »
Thanks!! My Infiniti has approximately 94,000 miles, it has been maintained properly since we purchased it at 49,000 miles and is driven in Southern California. No, it does not have a K&N filter or pop charger.
Thanks again and I'll post this in the mechanics forum. I wish I would have found this board sooner.
