MovieMaestro10 wrote:UPDATE- Got the code scanned and came up with bad knock sensors, both need replacing.
Seems to make sense with everything that's going on...And apparently these do not trip the check engine light, so they were indeed hidden codes.
Been looking for more info on how to replace them...Does the entire intake manifold have to be removed to get to them? Wondering if that job is worth it for a few MPGs.
The entire intake manifold (i.e. upper and lower plenum) *should* be removed to do the job properly.
Not saying the KS can't be replaced with the plenums on, but you don't get the full benefit.
by removing the upper plenum you also have easy access to the EGR pipe which undoubtedly needs cleaning. Removal also makes changeout of the DS vcg a snap and i recommend that as well, you were already talking plugs and coils so once those are removed then there really is no reason not to go ahead with the vcg.
by removing the lower plenum you have easy access to the KS, you can change the y-pipe hose, you can clean the lower plenum runners to spotless.
Having done both the G50 and the FGY33, I can tell you that the FGY33 is cake by comparison.
one more thought:
nissans (maybe other cars too, but especially nissans) LOVE to be taken apart. removing layers of the onion is usually not that bad and you are rewarded by gaining easy access. There are many instances where i've pissed away waaaaay too much time by trying to take a shortcut only to end up removing the interference anyway. re-assembly (for me anyway) is typically half to no more than 2/3 the time to tear down. they go back together very easily.
