vonscorpio »
https://forums.nicoclub.com/vonscorpio-u242950.html
Thu Aug 27, 2015 1:21 pm
My I30 is a daily driver and my commute is a hellish 1.5 hour a day, average speed 15 mph crawl. I got the car last October with 170,000 miles on it, with unknown maintenance history, but based on a bunch of other factors, it is to be assumed neglected.
Recently turned over 180,000 miles and I have noted an ever-so-slight hesitation when it shifts, specifically under load (i.e. driving up hill, delays dropping out of overdrive, even if I turn off the overdrive manually). The change is so slight I suspect no one else would notice it and may honestly not be an issue. However it's raised the reminder flag that I should probably change the fluid among other maintenance. The fluid is within normal operational levels, and does not smell burnt. It is a pinkish red, like the color of raw steak juice.
Which brings me to my big question: do I take it in and get it flushed? Do I buy a case of fluid and start the "drain and refill every 500 miles" routine? Should I drop the pan and replace the mesh? Do I leave it alone?
I have read on many forums, including Nicoclub, that flushing an old transmission can spell the beginning of the end, but I know ignoring it doesn't accomplish much more.
