vonscorpio »
https://forums.nicoclub.com/vonscorpio-u242950.html
Fri Jan 29, 2016 2:16 pm
I’ve got some new/worsening issues with my I30.
The history: the car has previously exhibited the “cold start, then die” symptoms, which I addressed by cleaning the mass air flow sensor (MAF) and replacing the fuel filter. After that operation the RPM was notably lower than usual, and it still didn’t solve the cold start issues (as mentioned in one of my previous posts, the car runs just fine after you tap the gas to get it started). I just had a friend replace the valve cover gaskets/spark plug tube gaskets, spark plugs and plenum gasket. Haven’t gotten around to cleaning the IACV or throttle yet.
After that operation I’ve had two new issues: the idle dropped even farther and the gas pedal “freezes” in resting position if it sits long enough. A solid tap gets it loose, but if you aren’t ready for it the extra pressure it takes when it sticks could launch you forward. The day after I was sitting at a traffic light and the RPM dipped and the vehicle started stuttering like it was thinking about stalling and the check engine light came on: code P0174 (bank 2 I believe). Few days later it stalled at idle. Drives fine otherwise.
Since I tried cleaning the MAF, I am inclined to believe I messed it up somehow. The symptoms are becoming identical my M30 when it’s MAF failed. All the O2 sensors are new, so I am less likely to suspect them—although the one right in front of the passenger firewall (the annoying one you have to pull off the front right wheel and wheel well to get to) was getting dripped on by the oil leak prior to the valve cover gasket job.
So, here are my questions:
Anyone familiar with possible root causes of a P0174?
Should I just replace the MAF and be done with it?
And possibly the biggest safety concern, is there a safe way to lubricate the throttle cable/fix the sticky pedal?
