I'll be doing it myself but I've got a couple of questions about this. I've read that someone changed their water pump and oil pump since they had the motor apart while doing the timing. The water pump I can understand, but should I really be worried about the oil pump? I thought oil pumps are usually good for a long time. Also, Napa has the entire timing kit (cam and crank gears, chain, tensioner and guides) for $135, but if its the guides that wear and make the noise, is there really going to be a lot of wear on the gears and chain? I'll buy everything if I have to but I'd hate to get the kit and see that the gears are mint. I would like to get all the parts I need before I tear it down so my truck is down for as little time as possible. So far I've got this for a list of parts I'm gonna buy:
- Valve cover gasket
Timing kit (gears, chain, tensioner, guides)
Water pump
Oil pan gasket
