o0Syn wrote:Do you do your own oil changes? If so make sure you fill up the fuel filter before putting it in. I forgot to do that once and mine was noisy as s*** on startup till i re-did it. Also the T-chain is not always the source of the clack, I did my t-chain and it still clacks like crazy cuz its the valves. So if you do both you will have a nice quiet truckie.
Im pretty sure its the chain as it does it only on startup with the oil low light on. After that it stop and only starts clacking again and certain RPM's. It also will not do it if I turn the truck off then right back on. My thinking is that the tensioner looses pressure due to bad seals and it losses pressure over time.
Towncivilian wrote:Pre-filling the oil filter does minimize dry starts after oil changes, but unless the anti-drainback valve on the oil filter is not sealing properly, future starts should not have any startup rattle. What oil filter are you running, Thor667?
I dont change my own oil. But I dont think its the oil filter anti-draneback as its always done it even just after oil changes.
