GareBear »
https://forums.nicoclub.com/garebear-u308221.html
Mon Jun 05, 2023 5:58 pm
So I finally got things situated enough to install a battery and see if it would start. No go. Engine cranks, but there is no spark. I have not checked the fuel pump as of yet, but in my attempts to start the truck, no noticeable noise is coming from it. As mentioned in my initial post, the 2 pin plug at the distributor does not have anything connected to it. I opened up the convoluted tubing that houses the wires for the other connector (6 or 7 pin) and I found two wires that were cut, a blue wire and a black with white tracer. Are these the two wires that are supposed to connect at the small 2 pin plug? I have no idea why these would be cut, but I have found two other connectors missing, the inlet air temp sensor and another one just below and to the front of the throttle body, which appears to have something to do with engine coolant/heater hose, not sure but it's green. I have tried to search wiring schematics for this issue, but I can't make heads or tales of the ones I've found. I've checked and confirmed voltage at all in dash fuses, voltage at all connectors integrated into the positive battery cable, two small ground wires at the main battery negative cable to inner fender mount and voltage supply to the fuel pump relay. If the two cut wires I found are in fact supposed to go to the 2 pin plug, which one goes to which side in the connector?
Thank you for your help
