1997 ECU Codes, WTF?
Booztd 3
Car: 1990 Nissan 300ZX TT
Ok ,so i searched for an hour on all the different write-up's on pulling ECU codes, and what issues the numbers reference.
After pulling the codes, I come up with....
25 - IACV-AAC Valve81 - Vacuum Cut bypass Valve87 - EVAP Canister Purge Control91 - Front o2 Sensor92 - ?93 - ?105 - EGR and canister control valve (Solenoid)132 - ?
Like I said I searched on these codes and I find nothing on 92, 93, or 132, and I've double checked I am looking at them correctly. I probably cycled through the codes 4-5 times just to ensure I wasnt mis-reading them.
Other than the CEL this car drives perfect. It doesnt idle funky, get terrible gas mileage, etc. I have noticed that the car has an exhaust leak, most likely why its throwing the o2 sensor code, however I have no idea why it would be throwing the IAC, EGR, Etc codes.......i have checked around and it does not seem it has a vaccum leak...
Any help is appreciated, thanks
Booztd 3
I was able to get an OBD-II code reader and print its codes, I Just found a service manual online and was able to find the following:
P0505: EC-217P1441: EC-260P0443: EC-195P0135: EC-132P0141: EC-139P0446: EC-203P1400: EC-251P1105: EC-236
Hopefully this will help me out.....
jesusgonzalez7
Car: 240sx 1998
sorry i can't help you, but can you tell me how can i check the codes? the thing is i can't find the mode selector.
