1997 altima P0400 & P0325 code
General discussion area for the U13-chassis Altima
eddiestar47
I recently did an intake manifold gasket repair for a P0304 (cylinder 4 misfire). I put it all back together and now I am getting a P0400 (insufficient egr flow) and a P0325 (Knock Sensor). I tried cleaning the egr because I read in a forum that a knock sensor code usually comes with another code, so they said to focus on the EGR. I removed the egr and applied vacuum it holds. I did the checks on the BPT and it as well holds vacuum. i even checked the solenoid valve and it is also working properly. I am stumped and I need some suggestions from someone who did the job and got the same codes or someone who knows why the codes appeared. Thanks in advance.
Ed
Return to “1st Generation Altima Sedan (1993-1997)”
