vader3120 »
https://forums.nicoclub.com/vader3120-u41145.html
Tue May 23, 2006 6:11 pm
I have a turboed 1997 Altima w/KA24DE
List of Mods:Revhard ManifoldT3/T40EJWT Fuel RailJWT ECU50# MSD InjectorsCobra MAFNismo FPRWalbro 255lph Fuel PumpCustom IC PipingProfec B Spec II Boost ControllerBoost GaugeFuel Pressure GaugePLX WidebandTial WGGreddy BOV
Car runs on 91 octaneNO TIMINGSTOCK INTERNALS
The Problem:The car was running good, not great, due to some air leaks, and exhaust leak, but it ran and made boost up to 13psi and it pulled great.
One day driving around a wire that i had hanging around for my turbo timer touched the frame of the car and sparked. Later on that day, i noticed the car was very sluggish, and didnt make boost. I stopped driving the car and took it in to a mech. He got the car running but it didnt fix the problem.
Whats NOT WrongIC system is fine, no leaksWastegate is fineEBC is fineTurbo is fineBOV is fineCap and rotor are newPlug wires are newPlugs are decent
Cars condition nowCar runs ok, not sluggish, but not tip top shape.Oil smells of gas, compression across the board is at 75/80/80/75.Last year april before turbo install compression was 160/162/165/162NO noticable smoke of anykind coming from anywhereA/F gets really rich about half throttle and on up it sits at about 10 or RICH on my PLXI assume that the continous rich condition before taking it in has ruined the piston rings, hence the smell of gas in the oil and the lack of compression.
Possible Reasons why:JWT ECU has something fried in it, i think and so does someone there (not ben) that this could have happend. That some where in the ECU, it has gone into some sort of gimp mode or reverted back to some orginal settings causeing those 50# injectors to flow to much.
Any thoughts or questions. I am thinking about rebuilding the engine, and going to install an AEM EMS, but i want to make sure that the wiring somewhere isnt fired.
Anyhelp would be great.
Thanks,Kenton
