1997 Altima "CODES"
dagovna
Car: music cars, thick chocolate women
hi all,I have a 1997 Altima with the check engine light.There are 2 codes1-300---engine misfire 2--171---engine too lean.What is the fix for these 2 codes. I don't want to reset the ecu until i fix the problem. I think it is bad plugs or timing resetand O2 sensor. Any help.. Thanks Dagovna
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
mmmm, try to pm reverand D, he's probably the man to talk to, he has ur year altima, im a 3rd gen owner myself and this isnt really my ball park, wish i could help, sorry man, and welcome to NICO
Importroller
Car: G35 and 07 Altima 3.5 6spd
on first gens, check the distributor. mine was messed up, but with a new one, i don't have those issues anymore. i don't have the list on my on how to fix the codes. but tomorrow, i will check alldata when im at work and get back to you.
Importroller
what model do you have XE, GXE, SE, or GLE? and are you positive those are the codes coming up?
Importroller
300: said that it could be a couple things improper spark plugs, insufficient compression, incorrect fuel pressure, EGR valve, injector signal shorted or open, intake leak, injector problem, ignition secondary circuit open or shorted, lack of fuel, or a magnetized flywheel
171: intake leak, front heated O2 sensor, injectors, exhaust leak, incorrect fuel pressure, lack of fuel or MAF
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Lean code. Well the 2 codes might be related for sure. A lean misfire. Altimas are known to have leaks at the intake manifold causing unmetered air to get past the MAF and would cause to a lean misfire. I would spray some carb cleaner around the intake manifold while the car is running to see if the RPM's jump. If they do that means the gasket is leaking and would be your lean code.
