Anyways the old was isn't out yet but in the meantime I was wondering about some differences in the two. I can't do alot of research myself because I am on dialup. I have a '97 with a 3.3 and 4wd. The engine and transmission I just got are a 3.5 from a '03 with 2wd.
Is the bellhousing different on the two? Is the transmission different and how is the 4wd setup? I wld really like to use the new transmission if I can. Does the end (don't know what its called) of the 2wd transmission unbolt or simply mate up to the transfer case somehow? And if not, can I use the old transmission or does it need a different bellhousing?
My other question is the throttle body on the new engine looks like it is controlled electronically, the 3.3s is mechanical. How is that setup? Is there a potentiometer the old cable to the pedal goes to or something?
also anyone have tips on unbolting the drive shafts? They just move and pickup slack and im about out of strength to turn the wrench by the time they stop.
Thanks
here is one of the heads. This isn't "the problem" but its what caused it. Its like the PO thought the oil and filter it came with from nissan was good enough to last 80k miles or so. i know this at least caused it to spin a main, ill find out what else after its outta the car.
