cookbeans »
https://forums.nicoclub.com/cookbeans-u241637.html
Mon Jul 04, 2016 8:02 am
Good morning all and Happy Independence Day !
This is my first post. My question is one that I've been puzzled by for 2 years.
My air-conditioner is intermittent and I've tried identifying the issue and cannot find it. The compressor works but then after it heats up or pressure gets high or it will kick off. I recharged the system with the aid of the Auto Skills Center at Ft. Campbell Ky.
I do have mechanics that have offered several solutions including but not limited to running a jumper wire from the ignition area over to the compressor to create more voltage. While that suggestion yields cold air I am suspicious it can cause damage to the harness and other wiring components.
Is it possible the dual pressure switch is faulty ? I jumped around it by unplugging the connector and closing the circuit with a piece of wire, but I think I did it wrong. The compressor didn't come on when I did that.
However when you jump from the battery it works fine. The relay on the passenger side of the engine compartment has been checked as well and it works.
Ok I'll wait for a reply !
