OutToWinPAHC wrote:
Are you bleeding them right?
As in not in? They should be tight. Have someone pump and hold the pedal, then you slightly open the valve, let it stop, then close it and have the person let go and do it all over. make sure you are starting from the RR side and ending with the FL side.[TRE05 wrote:97ka24DE] bleeder screws are down, do you think that is the problem?
there is your problem I believe. The air at the top of the caliper so when you bleed, the fluid comes out and not the air. Make sure you put the bleeder on the top and you should be good to go.[TRE05 wrote:97ka24DE]no like as in the bleeders are on the bottom of the front calipers not the top
