180fan »
https://forums.nicoclub.com/180fan-u3602.html
Fri Sep 12, 2003 7:11 am
You can also try changing your ATF. I changed mine out, and it shifted much more smoothly. I used Castrol ATF in the transmission, also swapped out the ATF strainer. Then the diff fluid actually did alot for me as well in terms of shifting smoothness. I do still get the slam feel initially, but when the ATF and gear oil start to warm up, it's very smooth. Give the fluid change a shot before a tear down of an AT as those get real expensive real fast.
