KingKarl »
https://forums.nicoclub.com/kingkarl-u27127.html
Wed Jul 27, 2005 1:20 am
I recently installed the B&M cooler using the Maxnix Method. If you have access to Infinity's FSBs, take a look at the "Service Procedure" in 00-042A. It relates to the factory's recommendation for cleaning the OE ATF cooler in the radiator of various year/models, which must be accomplished from the outlet side. the bulletin provides flow diagrams and year/model charts for reference as the flow direction varies by model and year. The ATF flow direction chart tells you which diagram is yours and is a little confusing to me. My reading of it is that the ATF enters the radiator cooler on the passenger side and exits back to the transmission on the driver's side on all Q45's from 1990 to 2001 model/year, indicating that what Max advises is correct.
