I know what your thinking. Another dreaaadful topic where I ask how I can improve my Q ever so slightly....
But Maxnix recently said that 1997-2001 Q45 (FGY33) front brakes would be an upgrade on a 1990-1996 Q45 (G50). I thought he was drunk when he said that and meant that the rear brakes from a FGY33 would be an upgrade. Well turns out the FGY33 has better brakes all around...The front rotors,pads and calipers are slightly bigger. The rear brakes consist of vented rotors which is a plus.
But the front calipers of the FGY33 have bigger pistons VS the smaller ones found on the G50. I assume this would move the brake bias more forward...
I ask these questions because the 1997 Q45 is able to stop from 60-0 MPH in 123 feet. The 1990 Q45 is able to stop from 60-0 MPH (I assume according to Q45Tech) in 129 feet. Sure the 1997 Q45 is 149 LBS lighter, Is that really significant enough to cause such a difference in braking distance?
http://www.motortrend.com/roadtests/112 ... ewall.html
using-the-tcs-pump-to-decrease-braking- ... 99123.html
