jimphill »
https://forums.nicoclub.com/jimphill-u15959.html
Sat May 01, 2004 9:21 pm
Thanks for the great information.
It turned out that I was completely wrong, and the TPS and throttle switch were fine.
I originally thought the switch was bad because it measured 39-80 ohms closed, even when removed, and when I shorted the connector pins for the switch the idle was completely smooth, even at 600 RPM. But when I tried this later the idle was again bad, and a brand new Hitachi switch also measured 70 ohms.
So I kept looking for vacuum leaks and bad connections, but then it was noticed that spark plug #4's boot occasionally arced 1/2" to the exhaust manifold heatshield. The boot looked perfectly fine, but the idle always smoothed out perfectly when the boot was rotated 180 degrees. The plug wires were Prestolite (original?), and the vehicle has only 56K miles on it.
I don't understand why the misfire never caused an OBD II code to be set and the MIL to come on because I thought that misfire was detected through variations in RPM, not by monitoring the sparks themselves.
