jrey1717 »
https://forums.nicoclub.com/jrey1717-u212163.html
Mon Feb 24, 2014 12:44 pm
Hi,
Just wanted to check with you guys in regards to an 02 sensor problem i have.
i have a 1997 QX4, and recently replaced the exhaust system. I was working with a local mechanic, and he did the 02 sensors. ( I replaced both downstream using Bosch sensors I got from advance)
When he cleared the codes, the check engine light was off, but as soon as i shut the truck off and started it back up, bam engine light throwing codes for the sensors we replaced.
I called the dealer and they want 110 for a diag, then 225 a piece for the sensors, then another 110 for the "flash" to the computer to update it to take the sensors. He said they have alot of problems with the sensors and it is generally corrected with the factory parts and flash. The parts I got off advance were OEM exact replacements and did not require a splice.
Does anyone have an opinion in regards to this. Do you think I just need a "flash" or I should take out the sensors and replace the with dealer ones. I can't belive the for those two sensors they want 450 in parts and 110 dollars for the diag and then the flash after.
Any input at this point helps, so far ive done trailing arm bushings, alternator, distributor, tire, brakes, shocks, headlamps, complete exhaust, and i had the timing belt snap 3 weeks after i bought it. Needless to say with a newborn baby in january I am getting tired of throwing away money we really need.
Thank you,
Jeff
