1997 - 01 Infiniti q45 wiring harness *need help*
tjmast13
Car: 1997 Infiniti Q45
I need some help. The section of wires that goes from the posotive battery terminal down to where it splits off into 2 parts. 1 where is goes to a plug which then leads to I believe part of the transmission wiring harness on the passenger side. 2 the other section splits off towards the driver side along the rack and pinion where it is plugged into a sensor on the R&P. It also combs around the oil pan in plastic casing and goes to a plug which also goes to part of the transmission wiring harness and also splits off to an 02 sensor on driver side on the exhaust. I need this entire wiring setup. Or any leads as to where to find one! Any one that has this I will gladly purchase! Thanks! 97-01 q45
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Pictures might help. but based on your description. I'd say a boneyard is your best bet.
