It has just under 94,000 miles on it. Actually all the rubber and the engine bay look pretty good. There is no overheating and plenty of power. I don't see oil in the radiator or coolant reservoir. I don't see milkshake in the oil dip stick, but there are tiny bubbles. I also have white smoke coming from the exhaust. That tells me it is water/radiator fluid. That is why I am thinking head gasket.
It is OBDII so I still need to hook it up for a diagnostics. However I am just preparing for the worst right now and planning the parts. When I first test drove it I did not notice anything. I drove it home 30 miles away and then I noticed the white smoke.
There is also a rough idle when reversing and sometimes at idle, so I am also thinking about the AAIC(IACV). Someone said it also might be a leak in the fuel system or a bad injector. I smell fuel in the cabin. Just a PITA of crap right now.
