NissanFairladyZ32 »
https://forums.nicoclub.com/nissanfairladyz32-u104963.html
Sun Jun 13, 2010 6:11 pm
So i went to go run the codes on my car turns out i have 6 codes
P0141 - Rear HO2S Heater RH Bank
P0161 - HO2S Heater LH Bank
P0443 - EVAP Canister Purge Control Solenoid Valve
P1155 - Wastegate Valve Control Solenoid Valve
P1400 - EGRC Solenoid Valve
P1401 - Temperature Sensor
The last owner pulled out the EGR system and i beleive did the coolant bypass and i just figured out i have aftermarket downpipes coming off the turbos and the cats were taking off and replaced with testpipes so i guess i have a full exhaust,
The bad part is im throwing all these codes for 02 sensors because i guess im missing the 2 that would go into the testpipe i see both of the front bank 02s coming off the turbo manifolds
is there a way to have my car tuned to ignore the EGR and perhaps solve my testpipe no cat problom, car runs great just seems to run a lil rich cause my catback is coverd in black carbon
Thanks for the help
