frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Fri Sep 12, 2014 8:43 am
Welcome to NICO!
Sorry to hear about your troubles with the truck.
We can help you out a bit further, but need a little more information- the model of your truck, which engine, 4wd or 2wd, and sub model (if there is one).
Off the bat though, I'd test for spark and fuel to confirm you have both. Pull a fuel injector and crank the engine over to see if there is fuel. If so, repeat with the spark plug wire. After that I'd look for any loose grounds or vacuum hoses that might've come loose. Also- check your timing and search for additional vacuum leaks. To search for vacuum leaks, spray carb cleaner in/around the vacuum lines while starting to see of the engine will rev and race the RPM's. They may be cracked or broken completely.
